Simple Inclinometer Accuracy?
Question asked by pacman on Apr 2, 2015
Latest reply on Apr 13, 2015 by Jacques Trichet
I require a simple inclinometer where the chip is mounted vertically to measure a tilt angle of +/- 20 degrees in the X and Y planes.
The Accuracy needs to be +/- 0.5 degrees. Since the chip is mounted vertically I assume I will need a 3-axis accelerometer.
I am considering using the FXLS8471Q however referring to the data sheet on Page 24 it says: “All Angles are accurate to +/- 2 degrees”
http://cache.freescale.com/files/sensors/doc/data_sheet/FXLS8471Q.pdf?pspll=1
