LVDS 24Bit 1920*1080 kernel階段極化問題
Question asked by Frank Weng on Mar 30, 2015
Latest reply on Jul 21, 2015 by 尚飞 汤
Branched to a new discussion
hi 您好
使用MX6點panel AUO21.5" 1920*1080 遇到在開機過程中極化的問題,但進到OS之後畫面正常
按照iMX6QD How to Add 24-bit LVDS Support in Android 的說明
請問是那裡還需要在作設定,在setenv 中ldb=spl0 就不會有任何輸出,如果是ldb=spl1會有時出現freescale loge,但顏色及解析度都不對,後來show freescale logo就變成極化現象在也看不到logo。
下面是提供的相關資訊,已卡很久請求協助,謝謝
90564.jpg開機過程中(ldb_disp_init 設定spl/dul..)發生極化
90563.jpg進到OS的畫面
uboot env set:
setenv bootargs console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,LDB-XGA,bpp=32,if=RGB24 ldb=spl1 video=mxcfb1:off video=mxcfb2:off fbmem=10M fb0base=0x27b00000 vmalloc=400M androidboot.console=ttymxc0 androidboot.hardware=FA33 ldo_active=on
  • kernel_imx/arch/arm/mach-mx6/board-FA33.c
static struct ipuv3_fb_platform_data sabresd_fb_data[] = {
         { /*fb0*/
         .disp_dev = "ldb",
         .interface_pix_fmt = IPU_PIX_FMT_RGB24,
         .mode_str = "LDB-XGA",
         .default_bpp = 24,
         .int_clk = false,
         .late_init = false,
static struct fsl_mxc_ldb_platform_data ldb_data = {
         .ipu_id = 0,
         .disp_id = 1,
         .ext_ref = 1,
         .mode =  LDB_SPL_DI1,
         .sec_ipu_id = 0,
         .sec_disp_id = 0,
  • kernel_imx/drivers/video/mxc/ldb.c
static struct fb_videomode ldb_modedb[] = {
          "LDB-WXGA", 60, 1280, 800, 14065,
          40, 40,
          10, 3,
          80, 10,
          0,
          FB_VMODE_NONINTERLACED,
          FB_MODE_IS_DETAILED,},
          {//for auo 21.5
           "LDB-XGA",60,1920,1080,13899,
            70,90,
            10,30,
             20,10
             0,
             0,},
static int ldb_disp_init(struct mxc_dispdrv_handle *disp,
  struct mxc_dispdrv_setting *setting)
                    reg = readl(ldb->control_reg);
644                 if ((lvds_channel == 0) && (setting->disp_id == 0))
645                         reg |= LDB_CH0_MODE_EN_TO_DI0;
646                 else if ((lvds_channel == 0) && (setting->disp_id == 1))
647                         reg |= LDB_CH0_MODE_EN_TO_DI1;
648                 else if ((lvds_channel == 1) && (setting->disp_id == 0))
649                         reg |= LDB_CH1_MODE_EN_TO_DI0;
650                 else
651                         reg |= LDB_CH1_MODE_EN_TO_DI1;
652                 ch_mask = lvds_channel ?  LDB_CH1_MODE_MASK :
653                                 LDB_CH0_MODE_MASK;
654                 ch_val = reg & ch_mask;
655
656                 if (bits_per_pixel(setting->if_fmt) == 24) {
657                         if (lvds_channel == 0)
658                                 reg |= LDB_DATA_WIDTH_CH0_24;
659                         else
660                                 reg |= LDB_DATA_WIDTH_CH1_24;
661                 } else {
662                         if (lvds_channel == 0)
663                                 reg |= LDB_DATA_WIDTH_CH0_18;
664                         else
665                                 reg |= LDB_DATA_WIDTH_CH1_18;
666                 }
667                 writel(reg, ldb->control_reg);<----設定完就極化
