Chris Lincoln
Mixed C & Assembly view when debugging
Discussion created by Chris Lincoln on Nov 8, 2007
Latest reply on Nov 9, 2007 by Dennis Shutt
Sorry for littering the boards with all of these nube questions. I've done some cursory searching of the forums and help files but haven't found the answer...
When debugging a C based project, is it possible to set a breakpoint on a C statement, but switch to the assembled code and step through the low level instructions?  Using CW 4 CF 6.4.
Alternately, what is the method of viewing the C compiler's generated code?
TIA,
Chris L.
