It is possible to generate the core dump when the application crashed on the Platform? If yes please let me know how we can do this.
i am using this compiling option.
"${ARM_ToolsDir}/mwccarm" -gccinc
Is there any way to enable more debugging and look into the system log.
Hello Vikas Sharma:
Please mention the device part number and the IDE or compiler platform you are using.
Regards!
Jorge Gonzalez
Hi Jorge,
I am using code warrior
CodeWarrior for MCU
Version: 10.6
Build Id:140329
Device :MK61FX512VMJ15
Please let me know if you need any more info
Vikas Sharma
Hello Vikas Sharma:
Thank you for replying with the information.
I am unclear on what you mean with "application crashed". Do you mean a hardfault? or the application running away?
If it's about dumping core registers during hardfault please check the next links:
Debugging Hard Faults on ARM Cortex-M | MCU on Eclipse
A Processor Expert Component to Help with Hard Faults | MCU on Eclipse
Regards!,
Jorge Gonzalez
