The "run/pause" light on CodeWarrior TAP is red?
peterzheng
I was trying to use the "Performance Analysis Tool" in CodeWarrior to profile a program on P4080DS. But the result is always 0. I found that on the CodeWarrior TAP, the "RUN/PAUSE" light is always red, while the "TX/RX" is green, which indicates OK. Could this be the reason why I always get 0 for the profiling?
How can I make the light of "RUN/PAUSE" go green again?
Peter
Tags (2)
peterzheng
BTW, the program is running fine. I can see what it wrote to the cache from CodeWarrior. Why the "run/pause" light is always red?
Also, inside the P4080DS, the Freescale hypervisor was deployed.
Peter
