Enable MIPI display on i.MX6DL
tonioch
Hello everyone,
I'm trying to enable the MIPI display (DSI) on my board and I've encountered some problems.
I tried to modify the file imx6qdl-sabresd.dtsi and set the status of mxcfb3 and lcd to okay but it didn't work neither:
mxcfb3: fb@2 {
        compatible = "fsl,mxc_sdc_fb";
        disp_dev = "lcd";
        interface_pix_fmt = "RGB565";
        mode_str ="CLAA-WVGA";
        default_bpp = <16>;
        int_clk = <0>;
        late_init = <0>;
        status = "okay";
lcd@0 {
        compatible = "fsl,lcd";
        ipu_id = <0>;
        disp_id = <0>;
        default_ifmt = "RGB565";
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_ipu1_1>;
        status = "okay";
I've got the following message when I'm booting the card with the image core-image-minimal:
mxc_mipi_dsi 21e0000.mipi: i.MX MIPI DSI driver probed
MIPI DSI driver module loaded
mxc_sdc_fb fb.32: register mxc display driver lcd
mxc_sdc_fb fb.32: ipu0-di0 already in use
mxc_sdc_fb: probe of fb.32 failed with error -16
I've also tried to change the disp_id of "&mipi_dsi" without success.
Anybody knows how to solve this?
Antoine
tonioch
I've found the answer, to enable the MIPI display, you have to disable the ldb display and change the disp_id and framebuffer of mipi_dsi on the imx6qdl-sabresd.dtsi file:
Here's my configuration in order to enable the mipi display, hope that will help you.
mxcfb1: fb@0 {
        disp_dev = "mipi_dsi";
        mode_str ="TRULY-WVGA";
        default_bpp = <16>;
        int_clk = <0>;
        late_init = <0>;
        status = "okay";
lcd@0 {
        ipu_id = <1>;
        disp_id = <1>;
        status = "okay";
&ldb {
          ipu_id = <1>;
          disp_id = <1>;
          ext_ref = <1>;
          mode = "sep1";
          sec_ipu_id = <1>;
          sec_disp_id = <0>;
          status = "disabled";
&mipi_dsi {
    dev_id = <0>;
    disp_id = <1>;  /* modif */
    lcd_panel = "TRULY-WVGA";
    disp-power-on-supply = <&reg_mipi_dsi_pwr_on>;
    resets = <&mipi_dsi_reset>;
    status = "okay";
tonioch
mxcfb1: fb@0 {
        default_bpp = <16>;
        int_clk = <0>;
        late_init = <0>;
        status = "okay";
lcd@0 {
        ipu_id = <1>;
        disp_id = <1>;
        status = "okay";
&ldb {
          ipu_id = <1>;
          disp_id = <1>;
          ext_ref = <1>;
          mode = "sep1";
          sec_ipu_id = <1>;
          sec_disp_id = <0>;
&mipi_dsi {
    dev_id = <0>;
    status = "okay";
