Eric Kerzinger
Can anybody explain the function "dfr16RFFT(pRFFT, pX, &zRFFTBuf);"??
Discussion created by Eric Kerzinger on Nov 6, 2007
Latest reply on Nov 9, 2007 by Pascal Irrle
I try to compute a signal with the FFT. The signal is received over an ultrasound sensor and is attached to ADC on the microcontroller.
Now my problem is when I use the function dfr16RFFT it doesn't work correctly
//FFT
dfr16RFFT (pRFFT, pX, &zRFFTBuf);
I start the program and it jumps into the function "dfr16bitrev.asm". it stays there and does not come out any more.
This is the code where the program stops:
********* dfr16bitrev.asm ************
chk_again
    sub       y0,d                        ; d=d-y0
    asr       y0                          ; y0=y0/2
    cmp.w     y0,d                        ; Check if d>=y0
    bge       chk_again                   ; If yes,check again
CodeWarriori version 8.0
Microcontroller: MC56F8037
Testboard: MC56F8037EVM
thx
Message Edited by Diplomand on 2007-11-06 10:59 AM
