is there a way to view global variables in the variables window like CodeWarrior does?
mikey1
I am just learning KDS v2.0.0 and am using PE universal multilink usb pod for debug.  When I step with the debugger I tried to add global variables to the variables windows and could not access the icons like I could in code warrior to add a global variable to the window.
Jorge_Gonzalez
Hello Michael,
I think this is related to the Eclipse version, KDS v2.0.0 is Eclipse Kepler, while the latest CW v10.6 was Eclipse Juno. You can use the "Expressions" view as explained by a colleague in the next link:
Variable Debugging with Eclipse Kepler | MCU on Eclipse
Regards!,
Jorge Gonzalez
Jorge_Gonzalez
Hello Michael,
Regards!,
Jorge Gonzalez
mikey1
Thanks for the link.  That should get me going
