Setting up TFTP client using MQX 4.1
Question asked by Darrell Talavera on Mar 20, 2015
Latest reply on Mar 26, 2015 by Radek Sestak
Hello everyone,
I am working on setting up my embedded program as a TFTP client using MQX 4.1 to download a file from a TFTP server
but have not succeeded yet. Below is my code snippet:
#define ENET_DEVICE             BSP_DEFAULT_ENET_DEVICE
#define ENET_IPADDR             IPADDR(192,168,55,128)
#define MAX_HOSTNAMESIZE        64
void setupTFTPclientAndDownloadFileFromServer()
    _ip_address          hostaddr;
    char                 hostname[MAX_HOSTNAMESIZE];
    uint_32              tftp_handle, buffer_size;
    uchar_ptr            buffer_ptr;
    TFTP_DATA_STRUCT     tftp_data;
    boolean              error = FALSE, error2;
    int_32               return_code = 0;
    int_32               i=0,address;
    boolean              next_trans = TRUE;
    _enet_address        enet_address;
    error2 = RTCS_create();
    if (error2 != RTCS_OK){
        printf("\nRTCS failed to initialize, error2 = %X", error2);
        _task_block();
    //Enable IP forwarding
    _IP_forward = TRUE;
    ENET_get_mac_address(ENET_DEVICE, ENET_IPADDR, enet_address);
    RTCS_resolve_ip_address("192.168.55.134", &hostaddr, hostname, MAX_HOSTNAMESIZE);
    if (!hostaddr) {
         printf("Unable to resolve host.\n");
         return;
    tftp_data.SERVER = hostaddr;
    tftp_data.FILENAME = "C:\\sampleFile.bin";
    tftp_data.FILEMODE = "octet";
                printf("\nDownloading file %s from TFTP server: %s [%ld.%ld.%ld.%ld]\n",
                        tftp_data.FILENAME, hostname, IPBYTES(hostaddr));
                tftp_handle = (*FT_TFTP->OPEN)((pointer) &tftp_data);
                if (tftp_handle != RTCS_OK) {
                    printf("\nError opening file %s\n", tftp_data.FILENAME);            //******THIS IS WHERE THE COMPILER ENDS UP
                else {
                    printf("\Success opening file %s\n", tftp_data.FILENAME);
                    while (!(*FT_TFTP->EOFT)()) {
                        next_trans = TRUE;
                        while(1) {
                            //Read TFTP
                            buffer_ptr = (*FT_TFTP->READ)( &buffer_size );
                            if((NULL == buffer_ptr)||(TFTP_DATA_SIZE != buffer_size)) {
                                next_trans = FALSE;
                            switch (buffer_size) {
                                case (RTCSERR_TFTP_TIMEOUT):
                                    printf("\nTFTP timeout\n");
                                    error = TRUE;
                                    break;
                                case (RTCSERR_TFTP_ERROR + 1):
                                    printf("\nFile %s not found\n", tftp_data.FILENAME);
                                    error = TRUE;
                                    break;
                                case (RTCSERR_TFTP_ERROR + 2):
                                    printf("\nAccess violation\n");
                                    error = TRUE;
                                    break;
                                case (RTCSERR_TFTP_ERROR + 3):
                                    printf("\nDisk full or allocation exceeded\n");
                                    error = TRUE;
                                    break;
                                case (RTCSERR_TFTP_ERROR + 4):
                                    printf("\nIllegal TFTP operation\n");
                                    error = TRUE;
                                    break;
                                case (RTCSERR_TFTP_ERROR + 5):
                                    printf("\nUnknown transfer ID\n");
                                    error = TRUE;
                                    break;
                                case (RTCSERR_TFTP_ERROR + 6):
                                    printf("\nFile already exists\n");
                                    error = TRUE;
                                    break;
                                case (RTCSERR_TFTP_ERROR + 7):
                                    printf("\nNo such user\n");
                                    error = TRUE;
                                    break;
                                default:
                                    break;
                            } //Endswitch
                            //Transaction finished
                                return_code = (*FT_TFTP->CLOSE)();
                                fclose(flash_hdl);
                        } //End Read TFTP
                        break;
I am not being able to get an RTCS_OK return value after calling this method (*FT_TFTP->OPEN)((pointer) &tftp_data) so it does not go to
the downloading process.
Please have a look at my code and advice what should be corrected. Thank you very much.
Darrell
