FRDM-KE04Z  KDS  ADC_LDD sample code compile errors
Question asked by George Chamberlayne on Mar 20, 2015
Hardware:-
FRDM-KE04Z PCB - with extra 10K Pot connected to the PKE04Z8VFK4 PTB2 pin. (Pot input +3V3 and GND)
Dev platform:-
Kinetis Design Studio and Processor Expert
Problem:-
ADC_LDD Component example code compile errors
Every second my Test program uses the ADC_LDD example code to read the ADC value of a Pot connected to PTB2 pin (J4 pin 1) and sets the intensity of the Red (RGB) Led PWM period accordingly.
I’m getting the following KDS compile errors.
'Building file: ../Sources/Events.c'
'Invoking: Cross ARM C Compiler'
../Sources/Events.c: In function 'TU2_OnCounterRestart':
../Sources/Events.c:195:46: error: 'LDD_ADC_Tsample' undeclared (first use in this function)
   Error = AD1_CreateSampleGroup(MyADCPtr, (LDD_ADC_Tsample *)SampleGroup, SAMPLE_GROUP_SIZE); // Set created sample group
../Sources/Events.c:195:63: error: expected expression before ')' token
../Sources/Events.c:195:63: error: too few arguments to function 'AD1_CreateSampleGroup'
NB:-
I’m new to Freescale and Kinetis processors.
The ‘old’ CW ‘ADC_poll_demo’ example code runs OK on my FRDM-KE04Z PCB.
Original Attachment has been moved to: KE04Z-_ADC_Test_01.zip
