All,
I remembered i.MX6 L3.0.35 supported dual LVDS display to set kernel parameter such as ldb=dul0.
Then I tried this for KK4.4.3 but some of them were ignored.
c.f. u-boot=> setenv mmcargs .... ldb=dul0
u-boot=> boot
The results were:
ldb=dul1 OK #dual (same output to 2 panels)
ldb=sep Fail(same as dul1) #serarate
ldb=spl1 Fail(same as dul1) #split (2 ports for 1 panel)
Is this parameter still valid/alive?
Thanks.
Solved! Go to Solution.
Hello Thorus,
Did this work for you with previous versions of android?.
As far as I know, android cannot send separate video through 2 different channels, that is why only dul1 works
Sergio
Hello Thorus,
Sergio
Dear Sergio,
Thank you for your reply.
Have a nice day.
