As question above, I am planning to program with twrk60d100m touch sensing module in KDS 2.0. All available sources that i found online are for code warrior or other platform. Is there any way to play on KDS 2.0? I download a touch sensing module library online, does anyone know how to import it to KDS? Thanks in advance.
Yaran
Original Attachment has been moved to: TSSSW_3_1_0.zip
Hi, Yaran
Would you please help to share the library you download? I will check it for you. I cannot find this library in KDS. Thanks.
Best Regards
Paul
