Hi.What image should i make for sabrelite board if i want rotate display.
felixtsaruev
Recently i made sdcard image by this guide Freescale/fsl-community-bsp-platform at master · GitHub
But after uboot-loading nothing appear. Black screen only.
Please help.
saurabh206
Senior Contributor III
Felix
Can you share boot up log?
Which hardware you are using?
"MACHINE=imx6qsabresd source ./setup-environment build"
Can you verify your board name is correctly used?
Saurabh
