We are not able to access DCU memory mapped registers from user mode (non-privileged) on Vybrid. Is there any specific settings we have to perform to make it happen?
Note: we are trying to access DCU registers starting from 0x40058000 address (Vybrid Reference Manual, Rev. 7, 06/2014 Page 3034)
Rizwan Rasheed
Solved! Go to Solution.
please download Vybrid Security Reference manual. There read mainly chapter #5 and chapter #7. There you will get more information about the CSU unit, which should allow you to set access rights to various NIC masters/slaves. If you have further questions, write them here and mention me (character '@' + my name).
Rene
@ReneKolarik, does MQX support user & supervisor modes? I'm told that There is no user-mode/supervisor-mode split in Vybrid
Were you able to acces the registers in user-mode.
Would you be nice enough to share your solution?
Alejandro
How can you tried access to registers? And do you read section "55.7 Register protection" on VYBRIDRM? It can be helpful.
Best Regards
Vilem
55.7 is about "Timing, Error and Interrupt Management" in Vybrid Reference Manual, Rev. 5, 07/2013. Has a section on Register protection been introduced? Perhaps this will explain why code that previously worked on a bare metal DCU demo, does not change the DCU registers (albeit on an MQX-based application).
Hi Kenneth,
In Vybrid Reference Manual rev. 7, 06/2014 is 55.7 about Register protection.
Vilem
