How to direct a simple graphics application to a different framebuffer?
Question asked by Sudipta subudhi on Mar 18, 2015
Latest reply on Apr 16, 2015 by Sudipta subudhi
I am using a simple graphics application VertexColors.c in gpu_sdk_v1.00 from freescale. It has main(), init(),render(),resize() as the function blocks. and the flow of calls is like
1.main() => init() (i.e. main() is calling init())
2.init() => resize()
3.after init(), main() => render()
and then  eglSwapBuffers(egldisplay, eglsurface) is called.
And now to direct it to /dev/fb1 i assume i have to include:
        int fd_fb,result;
        //Applying color key
        struct mxcfb_color_key color_key;
        color_key.color_key = 0x0;
        color_key.enable = 1;
        if ((fd_fb = open("/dev/fb1", O_RDWR, 0)) < 0)
        return 0;
        if ( ioctl(fd_fb, MXCFB_SET_CLR_KEY, &color_key) < 0) {
        printf("Error in applying Color Key\n");
        struct mxcfb_loc_alpha loc_alpha;
        ioctl(fd_fb, FBIOBLANK, FB_BLANK_NORMAL);
        loc_alpha.enable = 1;
        loc_alpha.alpha_in_pixel = 1;
        result = ioctl(fd_fb, MXCFB_SET_LOC_ALPHA, &loc_alpha);
        if (result < 0)
                printf("fb ioctl MXCFB_SET_LOC_ALPHA fail\n");
                //goto err1;
        ioctl(fd_fb, MXCFB_WAIT_FOR_VSYNC, 0);
        ioctl(fd_fb, FBIOBLANK, FB_BLANK_UNBLANK);
        close(fd_fb);
Please correct me if i am wrong or if i am missing any details. But, i wonder where to include this piece of code in the given application.
Thanks in advance.
Sudlin
