Hi, We are trying to clone mRTU52259 using twrmcf52259 by using MQX BSP cloning wizard.
We followed the steps mentioned in "Getting Started with Freescale MQX™ RTOS BSP Cloning Wizard" user guide..
Generate MQX projects icon was clicked and after Generating the MQX project.
In the console it is displaying stderr mentioned below...
stderr: D:\miniRTU52259\tools\generator\..\CodeWarriorNPW\miniRTU52259_32.reg (The system cannot find the path specified) *************************************************************************************
We are using MQX4.1.1 RTOS
One more problem was we couldnot generate the "build_libs.wds" ie .wds file in build folder.
Please tell us exact procedure to do the BSP cloning....................
Solved! Go to Solution.
Hello Praveen,
There is a patch for the cloning wizard, could you please install it?
You can find this patch at the below link
In addition, please check the video attached.
Sol
Hello Praveen,
Sol
we installed the patch u sent us...
That is working fine ....
But we want the cloned file to be created in our folder that is in D:drive.. From there i want to access the files and project.
But the cloned file is generated in c:drive/Freescale/build/..........
We used "Export Source tree in BSP cloning wizard". that is exporting all the files to D:drive...
But not the "build.wds file.....
I just wanted to know how to get all the file access from cloned file from D:drive
is this possible or not.......
thank u
praveen.s
