Hi Jim,
The EEPROM which you have mentioned above, is that a seperate EEPROM IC you are telling about, or the EEPROM in the controller.
I want to clarify this because when I go for a seperate IC for EEPROM, then I will get the typical 300k. But what about the EEPROM that is inbuilt in the controller.
Do I get the same 300k. I think it will be definitely less than 300k, say around 10k to 100k.
Please clarify me on this.
with regards,
Balaji.
