How to check signature of the OS under the Eboot?
garylijs
Hi all,
As the title, I don't find any code about the signature in the EBOOT, whether I need to prepare one routine called OEMCheckSignature, and then assign it to g_pOEMCheckSignature?
Bio_TICFSL
Hi gary,
Which BSP are you using? as far as I know the BLCOMMON is just used in MX27 Wince BSP, to store signatures images on NAND. there is no other verify implementation for MX5x or Mx6 BSPs.
garylijs
Hi Bio,
Thanks for your support first.
I use MX28 wince BSP. So I don't know how to do authertication under EBOOT when my OS is secure OS.
Gary
