In linux kernel 2.6.24 , support is provided for four SCCs controller, but still i am not able to use all four together.
1. Which Linux BSP you are using, where this BSP was obtained from?
2. Which board you are using - Freescale board (please specify board name) or custom?
3. Could you please describe the problem in more details - what you exactly doing and what is the result?
