Question about audio input using wm8692 on the SabreSD evk.
jesseforgues
Can anyone confirm that the WM8962 audio input on the SabreSD (smart devices) eval kit is only capable of mono mic input?
I was hoping to do some stereo input testing.
99         sound {
100                 compatible = "fsl,imx6q-sabresd-wm8962",
101                            "fsl,imx-audio-wm8962";
102                 model = "wm8962-audio";
103                 ssi-controller = <&ssi2>;
104                 audio-codec = <&codec>;
105                 audio-routing =
106                         "Headphone Jack", "HPOUTL",
107                         "Headphone Jack", "HPOUTR",
108                         "Ext Spk", "SPKOUTL",
109                         "Ext Spk", "SPKOUTR",
110                         "AMIC", "MICBIAS",
111                         "IN3R", "AMIC";
112                 mux-int-port = <2>;
113                 mux-ext-port = <3>;
114         };
Labels (3)
jesseforgues
Looking over the schematic it looks like I would have to rewire the SabreSD to use IN1L and IN1R and modify the device tree and codec driver as such.
Closing this issue.
CarlosCasillas
Hello Jesse,
Thanks for your contribution to the Community!
jesseforgues
correction WM8962 codec should have been my subject
