Help meee..!!
Tutoriales, ejemplos o algún sitio que me ayude a utilizar mi tarjeta FRDM-KL46Z. En especial como utilizar el LCD de dicho microconntrolador.
Saludos!
Help meee..!!
Saludos!
Try http://www.utasker.com/kinetis/FRDM-KL46Z.html
and
http://www.utasker.com/docs/uTasker/uTasker_SLCD.pdf
and
Mark
Kinetis: µTasker Kinetis support
KL46: µTasker FRDM-KL46Z support / µTasker Kinetis TWR-KL46Z48M support
For the complete "out-of-the-box" Kinetis experience and faster time to market
Hi Ana
I think u r looking for some basic tutorials to interface LCD in FRDM-KL46 board.
You can Check this link for that. For Pinouts of LCD,
using the above sheet u can configure the 7 Segment displays to display any digit. Here A,B,C,D,E,F,G are the 7 segments and 1,2,3,4 are the 4 Digits present in the LCD so using the combinations on the pins u can display digits, decimal(.) and colon(:) . Hope this helps.
Amit
Hi Ana Celia Medina Rocha,
Could please rewrite your quesiton in English? Then we can help you solved it.
Jingjing
