programming flash using .elf file
Question asked by T tech on Mar 10, 2015
Latest reply on Apr 12, 2015 by T tech
Hello Everyone,
I am using MK60FX512 controller, CW10.6 & MQX4.1.
Also I am using FlexEEPROM (did the partition).
If I programmed the flash with .elf file through flash programmer, flash is programmed successfully but application code doesn't execute.
and if I programmed flash with another .elf file (the code without EEPROM),application code runs successfully.
Please help me to resolve this problem.
Thanks.
