Does anyone have the K10DN512 .icf file? I want to make sure mine match up.
I keep getting this warning/error Stack pointer is setup to incorrect alignment. Stack addr = 0x1FFFFEFF whenever I do a download/debug
Solved! Go to Solution.
I redid the port with BSP cloning wizard. Didn't need to touch the icf file anymore. It is working now.
Hello Albert,
Could you please try using the attached file?
Sol
