Hi Rick,
Please make sure that you check that your Beekit version matches what the maxstream documentation states.
If you just downloaded our Beekit, then you probably have a version that is newer than what MaxStreams installer requires, and you should contact their support and request an update:
http://www.maxstream.net/support/knowledgebase/article.php?kb=168
