On this site many many many post about how to connect the imx6 by LVDS to LVDS monitor.
But no posts about how to connect the LVDS to not LVDS monitor , but with LVDS Channel Link on input DS90CR216.
How? how ? how? I am suffering for several months! Help me please!
I have board IMX6Q.
Now i truing to connect the monitor with DS90CR216. MONITOR IS NOT LVDS!
http://www.ti.com/lit/ds/symlink/ds90cr215.pdf
From DS90CR216 the signal going to TTL of monitor.
1. i set drivers/video/mxc/ldb.c parametrs of my monitor
2. Monitor is 18 bit and 3 pairs channel + 1 clk + GND
3. I connect it like on scheme, but what i will do with VDD power 3.3 on my IMX6 ? i need to disable somthing?
Becouse on the DS90CR216 Channel Link there is no need the VDD, there is onli input 3 pairs and 1 clock + GND.
4. i recompile the new kernel with my parametrs and send it to my board.
5. Then i starting my board with new parametrs
saveenv
Writing to MMC(3)... done
booti mmc3
But again, nothing
I trued with different parametrs.
setenv bootargs console=ttySAC0,115200 init=/init video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666,bpp=32 ldb=sin0 video=mxcfb1:off video=mxcfb2:off fbmem=48M vmalloc=400M androidboot.console=ttySAC0 androidboot.hardware=freescale
But nothing, no blinking, no flickering.
Prompt in what may still be problem? any ideas what to check?
Hi Andrey
DS90CR215/216 is general purpose lvds serializer/deserializer,
probably your monitor has non-standard signal mapping. I.MX6 LDB
has 18/24 bit JEIDA/SPWG/PSWG/VESA mapping as shown
on IMX6DQRM sect.39.5.2 Bit Mapping. You can try to check that
with oscilloscope. Also one should to know what is real resolution
supported by that particular monitor, if for example this is 1024x600
it will not work with XGA or 1080P. Chapter 18,19 MX53UG
shows how to add new LCD to Linux and link below shows
support for some LCD resolutions
http://boundarydevices.com/configuring-i-mx6-machines-different-screens-nitrogen6x-sabre-lite/
1. I checked the Bit mapping, it's okey. (SPWG) i tried to start with ch0_map=SPWG
2. I tried with lot of configuration of resolution, i tried to take default parameters from /drivers/video/modedb.c
but nothing.....
