I'm encountering some thermal problems with my enclosure design and was wondering if it would be to reduce the clock speed from like 800mhz to 600mhz.
Also what is the recommended operating temperature for the CPU core? Aka the temp reading from /sys/class/hwmon/hwmon0/device/temp0_input.
Thanks!
Solved! Go to Solution.
Hi Gavin
clock speed can be reduced, please look at appnote describing
temperature management in details:
AN4579 i.MX 6 Series Thermal Management Guidelines
Chapter 26 Thermal Driver attached Linux Manual describes linux thermal
driver.
Hi Gavin
driver.
