ARM_Programmer specify programmer
Question asked by Matthew Harper on Mar 5, 2015
Latest reply on Mar 6, 2015 by Matthew Harper
I was looking at the command line options for the ARM_Programmer.exe utility and noticed there is no option to specify the programmer.  You can specify a programmer in GUI via the drop down.
It's potentially important because I have 'gang of four' situation, programming 4 boards at a time.
Also was looking into building the code via msys.  I'm assuming everything is built under msys? x Except the documentation?  Related to that I noticed on the web page you say
Run the command CollectExternalFiles.  This appears commented out. Should I use Collect Shared files instead?
Thx
