Light Weight Semaphore
snehahegde
I am using the TWRK70F120M and the IAR compiler in my project and I am trying to save the screen calibration values into Flash. I have got two tasks , one of which is the PegTask in which the calibration screen values are initialised and the Main Task in which I am trying to write and read those values into Flash. In order to share the data between the two tasks, I am trying to use the light weight semaphore. But  once I read it from Flash, control gets into the MQX interrupt handler.
PFA the code for PegTouch Task. Also, I have attached the code where I am writing and reading the calibration values to and From Flash. Please let me know how this can be resolved.
Thanks and Regards,
Sneha Hegde
Original Attachment has been moved to: PegTask.txt.zip
Original Attachment has been moved to: FlashTask.txt.zip
soledad
Hello Sneha,
Could you please let me know which MQX version are you using???
Soledad
