I am using CodeWarrior 5.1 for HCS12.
I want to disable a warning message (C5909) for a few lines and then re-enable it.
I know that I must use this line to disable it.
#pragma MESSAGE WARNING DISABLE C5909
However, I don't know how to re-enable it.
while(*pbuf++ = *s++);
#pragma MESSAGE WARNING ENABLE C5909
I tried with ENABLE instead of DISABLE but that is not working.
Any idea how to perform this ?
ssinfod
hi ssinfod,
1. according to Codewarrior compiler manual : This pragma (as other pragmas) has to be specified outside of the function's scope. For example, it is not possible to change a message inside a function or for a part of a function.
pls be aware of this point.
2. use '#pragma MESSAGE DEFAULT C5909 " or "#pragma MESSAGE WARNING" to enable it again.
I attached my demo code, it's for C1420 but the method is the same for C5909.
can this help?
Zhang Jun
