Generic exception handler, how to know WHY?
Question asked by Massimiliano Sturla on Mar 4, 2015
Hi to all, Debugging several time my app I encountred many time the generic default exception handelr;
I'm, developing with KDS 2.0.0 with K20, K60, K64 uP...
How to know what is the specific event that generated the exception? Several time with "GDB trace" I found important information but not everytime! I suppose that there is a way to know what is the event that generated excpetion or, it will be perfect, what line or C instruction (not assembly but C code line) generated theat!
Can someone help me?
Generic excpetion handler that I encountred many time is this:
    .pool
    .size Reset_Handler, . - Reset_Handler
    .align 1
    .thumb_func
    .weak DefaultISR
    .type DefaultISR, %function
DefaultISR:
    b DefaultISR
    .size DefaultISR, . - DefaultISR
/*    Macro to define default handlers. Default handler
*    will be weak symbol and just dead loops. They can be
*    overwritten by other handlers */
    .macro def_irq_handler handler_name
    .weak \handler_name
    .set  \handler_name, DefaultISR
    .endm
/* Exception Handlers */
    def_irq_handler    NMI_Handler
    def_irq_handler    HardFault_Handler
    def_irq_handler    MemManage_Handler
    def_irq_handler    BusFault_Handler
    def_irq_handler    UsageFault_Handler
    def_irq_handler    SVC_Handler
    def_irq_handler    DebugMon_Handler
    def_irq_handler    PendSV_Handler
    def_irq_handler    SysTick_Handler
    def_irq_handler    DMA0_IRQHandler
    def_irq_handler    DMA1_IRQHandler
    def_irq_handler    DMA2_IRQHandler
    def_irq_handler    DMA3_IRQHandler
    def_irq_handler    DMA4_IRQHandler
    def_irq_handler    DMA5_IRQHandler
    def_irq_handler    DMA6_IRQHandler
    def_irq_handler    DMA7_IRQHandler
    def_irq_handler    DMA8_IRQHandler
    def_irq_handler    DMA9_IRQHandler
    def_irq_handler    DMA10_IRQHandler
    def_irq_handler    DMA11_IRQHandler
    def_irq_handler    DMA12_IRQHandler
    def_irq_handler    DMA13_IRQHandler
    def_irq_handler    DMA14_IRQHandler
    def_irq_handler    DMA15_IRQHandler
    def_irq_handler    DMA_Error_IRQHandler
    def_irq_handler    MCM_IRQHandler
    def_irq_handler    FTFL_IRQHandler
    def_irq_handler    Read_Collision_IRQHandler
    def_irq_handler    LVD_LVW_IRQHandler
    def_irq_handler    LLW_IRQHandler
    def_irq_handler    WDOG_EWM_IRQHandler
    def_irq_handler    RNG_IRQHandler
    def_irq_handler    I2C0_IRQHandler
    def_irq_handler    I2C1_IRQHandler
    def_irq_handler    SPI0_IRQHandler
    def_irq_handler    SPI1_IRQHandler
    def_irq_handler    SPI2_IRQHandler
    def_irq_handler    CAN0_ORed_Message_buffer_IRQHandler
    def_irq_handler    CAN0_Bus_Off_IRQHandler
    def_irq_handler    CAN0_Error_IRQHandler
    def_irq_handler    CAN0_Tx_Warning_IRQHandler
    def_irq_handler    CAN0_Rx_Warning_IRQHandler
    def_irq_handler    CAN0_Wake_Up_IRQHandler
    def_irq_handler    I2S0_Tx_IRQHandler
    def_irq_handler    I2S0_Rx_IRQHandler
    def_irq_handler    CAN1_ORed_Message_buffer_IRQHandler
    def_irq_handler    CAN1_Bus_Off_IRQHandler
    def_irq_handler    CAN1_Error_IRQHandler
    def_irq_handler    CAN1_Tx_Warning_IRQHandler
    def_irq_handler    CAN1_Rx_Warning_IRQHandler
    def_irq_handler    CAN1_Wake_Up_IRQHandler
    def_irq_handler    Reserved59_IRQHandler
    def_irq_handler    UART0_LON_IRQHandler
    def_irq_handler    UART0_RX_TX_IRQHandler
    def_irq_handler    UART0_ERR_IRQHandler
    def_irq_handler    UART1_RX_TX_IRQHandler
    def_irq_handler    UART1_ERR_IRQHandler
    def_irq_handler    UART2_RX_TX_IRQHandler
    def_irq_handler    UART2_ERR_IRQHandler
    def_irq_handler    UART3_RX_TX_IRQHandler
    def_irq_handler    UART3_ERR_IRQHandler
    def_irq_handler    UART4_RX_TX_IRQHandler
    def_irq_handler    UART4_ERR_IRQHandler
    def_irq_handler    UART5_RX_TX_IRQHandler
    def_irq_handler    UART5_ERR_IRQHandler
    def_irq_handler    ADC0_IRQHandler
    def_irq_handler    ADC1_IRQHandler
    def_irq_handler    CMP0_IRQHandler
    def_irq_handler    CMP1_IRQHandler
    def_irq_handler    CMP2_IRQHandler
    def_irq_handler    FTM0_IRQHandler
    def_irq_handler    FTM1_IRQHandler
    def_irq_handler    FTM2_IRQHandler
    def_irq_handler    CMT_IRQHandler
    def_irq_handler    RTC_IRQHandler
    def_irq_handler    RTC_Seconds_IRQHandler
    def_irq_handler    PIT0_IRQHandler
    def_irq_handler    PIT1_IRQHandler
    def_irq_handler    PIT2_IRQHandler
    def_irq_handler    PIT3_IRQHandler
    def_irq_handler    PDB0_IRQHandler
    def_irq_handler    USB0_IRQHandler
    def_irq_handler    USBDCD_IRQHandler
    def_irq_handler    ENET_1588_Timer_IRQHandler
    def_irq_handler    ENET_Transmit_IRQHandler
    def_irq_handler    ENET_Receive_IRQHandler
    def_irq_handler    ENET_Error_IRQHandler
    def_irq_handler    Reserved95_IRQHandler
    def_irq_handler    SDHC_IRQHandler
    def_irq_handler    DAC0_IRQHandler
    def_irq_handler    DAC1_IRQHandler
    def_irq_handler    TSI0_IRQHandler
    def_irq_handler    MCG_IRQHandler
    def_irq_handler    LPTMR0_IRQHandler
    def_irq_handler    Reserved102_IRQHandler
    def_irq_handler    PORTA_IRQHandler
    def_irq_handler    PORTB_IRQHandler
    def_irq_handler    PORTC_IRQHandler
    def_irq_handler    PORTD_IRQHandler
    def_irq_handler    PORTE_IRQHandler
    def_irq_handler    Reserved108_IRQHandler
    def_irq_handler    Reserved109_IRQHandler
    def_irq_handler    SWI_IRQHandler
    def_irq_handler    Reserved111_IRQHandler
    def_irq_handler    Reserved112_IRQHandler
    def_irq_handler    Reserved113_IRQHandler
    def_irq_handler    Reserved114_IRQHandler
    def_irq_handler    Reserved115_IRQHandler
    def_irq_handler    Reserved116_IRQHandler
    def_irq_handler    Reserved117_IRQHandler
    def_irq_handler    Reserved118_IRQHandler
    def_irq_handler    Reserved119_IRQHandler
    .end
