我最近在调试MMA7660,其他都行,就是中断一开始是高电平,位置变化后变为低电平,无法恢复为高电平
Question asked by zhang yunfeng on Mar 4, 2015
Latest reply on Mar 4, 2015 by zhang yunfeng
下面是我的代码:
*  mma7660.c - Linux kernel modules for 3-Axis Orientation/Motion
*  Detection Sensor
*  Copyright (C) 2009-2010 Freescale Semiconductor Ltd.
*  This program is free software; you can redistribute it and/or modify
*  it under the terms of the GNU General Public License as published by
*  the Free Software Foundation; either version 2 of the License, or
*  (at your option) any later version.
*  This program is distributed in the hope that it will be useful,
*  but WITHOUT ANY WARRANTY; without even the implied warranty of
*  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
*  GNU General Public License for more details.
*  You should have received a copy of the GNU General Public License
*  along with this program; if not, write to the Free Software
*  Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
#include <linux/module.h>
#include <linux/init.h>
#include <linux/slab.h>
#include <linux/i2c.h>
#include <linux/mutex.h>
#include <linux/delay.h>
#include <linux/interrupt.h>
#include <linux/irq.h>
#include <linux/hwmon-sysfs.h>
#include <linux/err.h>
#include <linux/hwmon.h>
#include <linux/fsl_devices.h>
#include <linux/gpio.h>
* Defines
#if 1
#define assert(expr)\
        if(!(expr)) {\
        printk( "Assertion failed! %s,%d,%s,%s\n",\
        __FILE__,__LINE__,__func__,#expr);\
#else
#define assert(expr) do{} while(0)
#endif
#define MMA7660_DRV_NAME "mma7660"
#define MMA7660_XOUT   0x00
#define MMA7660_YOUT   0x01
#define MMA7660_ZOUT   0x02
#define MMA7660_TILT   0x03
#define MMA7660_SRST   0x04
#define MMA7660_SPCNT   0x05
#define MMA7660_INTSU   0x06
#define MMA7660_MODE   0x07
#define MMA7660_SR   0x08
#define MMA7660_PDET   0x09
#define MMA7660_PD   0x0A
#define MK_MMA7660_SR(FILT, AWSR, AMSR)\
(FILT<<5 | AWSR<<3 | AMSR)
#define MK_MMA7660_MODE(IAH, IPP, SCPS, ASE, AWE, TON, MODE)\
(IAH<<7 | IPP<<6 | SCPS<<5 | ASE<<4 | AWE<<3 | TON<<2 | MODE)
#define MK_MMA7660_INTSU(SHINTX, SHINTY, SHINTZ, GINT, ASINT, PDINT, PLINT, FBINT)\
(SHINTX<<7 | SHINTY<<6 | SHINTZ<<5 | GINT<<4 | ASINT<<3 | PDINT<<2 | PLINT<<1 | FBINT)
#define MODE_CHANGE_DELAY_MS 100
ssize_t show_orientation(struct device *dev, struct attribute *attr, char *buf);
ssize_t show_axis_force(struct device *dev, struct attribute *attr, char *buf);
ssize_t show_xyz_force(struct device *dev, struct attribute *attr, char *buf);
static struct device *hwmon_dev;
static int test_test_mode = 0;
static struct i2c_client *mma7660_i2c_client=NULL;
//static struct mxc_mma7660_platform_data* plat_data; //Lynn
static u8 orientation;
static SENSOR_DEVICE_ATTR(all_axis_force, S_IRUGO, show_xyz_force, NULL, 0); //defined in linux/include/linux/hwmon-sysfs.h, line 34
static SENSOR_DEVICE_ATTR(x_axis_force, S_IRUGO, show_axis_force, NULL, 0);
static SENSOR_DEVICE_ATTR(y_axis_force, S_IRUGO, show_axis_force, NULL, 1);
static SENSOR_DEVICE_ATTR(z_axis_force, S_IRUGO, show_axis_force, NULL, 2);
static SENSOR_DEVICE_ATTR(orientation, S_IRUGO, show_orientation, NULL, 0);
static struct attribute* mma7660_attrs[] =
&sensor_dev_attr_all_axis_force.dev_attr.attr,
&sensor_dev_attr_x_axis_force.dev_attr.attr,
&sensor_dev_attr_y_axis_force.dev_attr.attr,
&sensor_dev_attr_z_axis_force.dev_attr.attr,
&sensor_dev_attr_orientation.dev_attr.attr,
NULL
static const struct attribute_group mma7660_group =
.attrs = mma7660_attrs,
static void mma7660_read_xyz(int idx, s8 *pf)
  s32 result;
  assert(mma7660_i2c_client);
  do
   result=i2c_smbus_read_byte_data(mma7660_i2c_client, idx+MMA7660_XOUT);
   assert(result>=0);
  }while(result&(1<<6)); //read again if alert
  *pf = (result&(1<<5)) ? (result|(~0x0000003f)) : (result&0x0000003f);
  printk("dbg:mma7660_read_xyz()/*pf=0x%x\n",*pf);
static void mma7660_read_tilt(u8* pt)
  u32 result;
  do
   result = i2c_smbus_read_byte_data(mma7660_i2c_client, MMA7660_TILT);
   assert(result>0);
  *pt = result & 0x000000ff;
static int print_orientation(int orient,char *buf)
  int result =0 ;
  char buf1[10],buf2[10];
  switch((orient>>2)&0x07)
  case 1:
   //result = sprintf(buf, "Left\n");
   result = sprintf(buf1, "Left");
   break;
  case 2:
   //result = sprintf(buf, "Right\n");
   result = sprintf(buf1, "Right");
   break;
  case 5:
   //result = sprintf(buf, "Downward\n");
   result = sprintf(buf1, "Downward");
   break;
  case 6:
   //result = sprintf(buf, "Upward\n");
   result = sprintf(buf1, "Upward");
   break;
  default:
   result = sprintf(buf1, "Unknown");
   switch(orient & 0x03)
   case 1:
    //result = sprintf(buf, "Front\n");
    result = sprintf(buf2, "Front");
    break;
   case 2:
    //result = sprintf(buf, "Back\n");
    result = sprintf(buf2, "Back");
    break;
   default:
    //result = sprintf(buf, "Unknown\n");
    result = sprintf(buf2, "Unknown");
  result=sprintf(buf,"%s,%s",buf1,buf2);
  return result;
  int result;
  result = print_orientation(orientation,buf);
   return result;
  int i;
  s8 xyz[3];
  for(i=0; i<3; i++)
   mma7660_read_xyz(i, &xyz);
  printk("dbg:show_xyz_force()/(xyz[0]=%d,xyz[1]=%d,xyz[2]=%d)\n", xyz[0], xyz[1], xyz[2]);
  return sprintf(buf, "(%d,%d,%d)\n", xyz[0], xyz[1], xyz[2]);
  s8 force;
  int n = to_sensor_dev_attr(attr)->index;
  mma7660_read_xyz(n, &force);
  printk("dbg:show_axis_force()/force=%d\n", force);
  return sprintf(buf, "%d\n", force);
static void mma7660_worker(struct work_struct *work)
u8 tilt, new_orientation;
char buf1[20],buf2[20];
int result=0;
mma7660_read_tilt(&tilt);
new_orientation = tilt & 0x1f;
if(orientation!=new_orientation){
  //printk("dbg:/mma7660_worker(),orientation=%d,new_orientation=%d\n",orientation,new_orientation);
  print_orientation(orientation,buf1);
  print_orientation(new_orientation,buf2);
  printk("dbg:/mma7660_worker(),orientation changes from %s to %s\n",buf1,buf2);
  orientation = new_orientation;
  //enter Active + Auto-Wake mode again
  if(mma7660_i2c_client)
   result = i2c_smbus_write_byte_data(mma7660_i2c_client,
    MMA7660_MODE, MK_MMA7660_MODE(0, 0, 0, 0, 0, 0, 0));  //enter standby
    assert(result==0);
    //MMA7660_MODE, MK_MMA7660_MODE(0, 1, 0, 0, 0, 0, 1));
    MMA7660_MODE, MK_MMA7660_MODE(0, 1, 0, 1, 1, 0, 1));  //IPP=1,ASE=1,AWE=1,MODE=1
    assert(result==0);
else
  printk("dbg:/mma7660_worker(),exit Auto-Sleep mode to Auto-Wake mode\n");
DECLARE_WORK(mma7660_work, mma7660_worker);
// interrupt handler
static irqreturn_t mmx7660_irq_handler(int irq, void *dev_id)
schedule_work(&mma7660_work);
printk("dbg:/mmx7660_irq_handler(irq=%d,dev_id=%s)\n",irq,(char*)dev_id);
return IRQ_RETVAL(1);
* Initialization function
static int mma7660_init_client(struct i2c_client *client)
int result;
int irq;
struct hrtimer timer;
printk("%s %d\n", __func__, __LINE__);
mma7660_i2c_client = client;
//plat_data = (struct mxc_mma7660_platform_data *)client->dev.platform_data;
//assert(plat_data);
if(test_test_mode)
   * Probe the device. We try to set the device to Test Mode and then to
   * write & verify XYZ registers
  result = i2c_smbus_write_byte_data(client, MMA7660_MODE,MK_MMA7660_MODE(0, 0, 0, 0, 0, 1, 0));
  assert(result==0);
  mdelay(MODE_CHANGE_DELAY_MS);
  result = i2c_smbus_write_byte_data(client, MMA7660_XOUT, 0x2a);
  assert(result==0);
  result = i2c_smbus_write_byte_data(client, MMA7660_YOUT, 0x15);
  assert(result==0);
  result = i2c_smbus_write_byte_data(client, MMA7660_ZOUT, 0x3f);
  assert(result==0);
  result = i2c_smbus_read_byte_data(client, MMA7660_XOUT);
  printk("%s x %x\n",__func__, result);
  result= i2c_smbus_read_byte_data(client, MMA7660_YOUT);
printk("%s y %x\n",__func__, result);
  result= i2c_smbus_read_byte_data(client, MMA7660_ZOUT);
  printk("%s z %x\n",__func__, result);
  assert(result=0x3f);
// Enable Orientation Detection Logic
//printk("result=i2c_smbus_write_byte_data(client, MMA7660_MODE, MK_MMA7660_MODE(0, 0, 0, 0, 0, 0, 0))=%d\n",result);
assert(result==0);
result = i2c_smbus_write_byte_data(client, MMA7660_SRST, 0x03); //AWSRS=1,AMSRS=1
  MMA7660_SR, MK_MMA7660_SR(2, 2, 1));    //REG = 0x08,sample rate reg,
  //MMA7660_SR, MK_MMA7660_SR(2, 2, 2));    //REG = 0x08,sample rate reg,
       //FILT = 2, 3 measurement samples at the rate set by AMSR[2:0]  or AWSR[1:0]
       //          have to match before the device updates portrait/landscape data
       //          in TILT(0x03) register.
       //AWSR = 2, 8 Samples/Second Auto-Wake Mode
       //AMSR = 1, 64 Samples/Second Active and Auto-Sleep Mode
       //AMSR = 2, 32 Samples/Second Active and Auto-Sleep Mode
//printk("result=i2c_smbus_write_byte_data(client, MMA7660_SR, MK_MMA7660_SR(2, 2, 1));= %d\n",result);
assert(result==0);
   MMA7660_INTSU, MK_MMA7660_INTSU(0, 0, 0, 0, 1, 0, 1, 1));
   //MMA7660_INTSU, MK_MMA7660_INTSU(1, 1, 1, 1, 1, 1, 1, 1));
        // ASINT =1 , Exiting Auto-Sleep causes an interrupt
        // PLINT =1 , Up/Down/Right/Left position change causes an interrupt
        // FBINT =1 , Front/Back position change causes an interrupt
  //printk("result=i2c_smbus_write_byte_data(client, MMA7660_INTSU, MK_MMA7660_INTSU(0, 0, 0, 0, 1, 0, 1, 1));= %d\n",result);
  assert(result==0);
   MMA7660_SPCNT, 0xA0);
  //printk("result=i2c_smbus_write_byte_data(client, MMA7660_SPCNT, 0xA0); = %d\n",result);
  assert(result==0);
   //MMA7660_MODE, MK_MMA7660_MODE(0, 1, 0, 1, 1, 0, 1));    //IPP=1,ASE=1,AWE=1,MODE=1
  //printk("result=i2c_smbus_write_byte_data(client, MMA7660_MODE, MK_MMA7660_MODE(0, 1, 0, 0, 0, 0, 1)); = %d\n",result);
  assert(result==0);
  // MMA7660's INT is connected to imx51 EVK's GPIO4_17
  // We install interrupt handler here
  //printk("plat_data->irq=%d\n",plat_data->irq);
  //assert(plat_data->irq);
  client->irq = 13;
  result = request_irq(client->irq, mmx7660_irq_handler,
   IRQF_TRIGGER_FALLING , MMA7660_DRV_NAME, NULL);
  assert(result==0);
   u8 tilt; char buf1[20];
   orientation = tilt&0x1f;
   printk("dbg:/mma7660_init_client(),init state %s\n",buf1);
  return result;
static struct input_polled_dev *mma7660_idev;
#define POLL_INTERVAL  100
#define INPUT_FUZZ 4
#define INPUT_FLAT 4
#include <linux/input-polldev.h>
static void report_abs(void)
  int i;
  s8 xyz[3];
  s16 x, y, z;
  for(i=0; i<3; i++)
  /* convert signed 10bits to signed 16bits */
  x = (short)(xyz[0] << 6) >> 6;
  y = (short)(xyz[1] << 6) >> 6;
  z = (short)(xyz[2] << 6) >> 6;
  input_report_abs(mma7660_idev->input, ABS_X, x);
  input_report_abs(mma7660_idev->input, ABS_Y, y);
  input_report_abs(mma7660_idev->input, ABS_Z, z);
  input_sync(mma7660_idev->input);
  printk("dbg:report_abs()/x=%d,y=%d,z=%d\n",x,y,z);
static void mma7660_dev_poll(struct input_polled_dev *dev)
report_abs();
/////////////////////////end//////
* I2C init/probing/exit functions
static int __devinit mma7660_probe(struct i2c_client *client,
       const struct i2c_device_id *id)
  int result;
  struct i2c_adapter *adapter = to_i2c_adapter(client->dev.parent);
  struct input_dev *idev;
  if(!i2c_check_functionality(adapter,  I2C_FUNC_SMBUS_BYTE|I2C_FUNC_SMBUS_BYTE_DATA))
         printk("%s I2C check functionality failed.\n",__func__);
         return -ENODEV;
  //assert(result);
  /* Initialize the MMA7660 chip */
  result = mma7660_init_client(client);
  assert(result==0);
  result = sysfs_create_group(&client->dev.kobj, &mma7660_group);
  assert(result==0);
  hwmon_dev = hwmon_device_register(&client->dev);
  assert(!(IS_ERR(hwmon_dev)));
  dev_info(&client->dev, "build time %s %s\n", __DATE__, __TIME__);
  /*input poll device register */
  mma7660_idev = input_allocate_polled_device();
  if (!mma7660_idev) {
   dev_err(&client->dev, "alloc poll device failed!\n");
   result = -ENOMEM;
   return result;
  mma7660_idev->poll = mma7660_dev_poll;
  mma7660_idev->poll_interval = POLL_INTERVAL;
  idev = mma7660_idev->input;
  idev->name = MMA7660_DRV_NAME;
  idev->id.bustype = BUS_I2C;
  idev->dev.parent = &client->dev;
  idev->evbit[0] = BIT_MASK(EV_ABS);
  //set absolute  coordinate maximum range (-512,512) ?
  input_set_abs_params(idev, ABS_X, -512, 512, INPUT_FUZZ, INPUT_FLAT);
  input_set_abs_params(idev, ABS_Y, -512, 512, INPUT_FUZZ, INPUT_FLAT);
  input_set_abs_params(idev, ABS_Z, -512, 512, INPUT_FUZZ, INPUT_FLAT);
  result = input_register_polled_device(mma7660_idev);
  if (result) {
   dev_err(&client->dev, "register poll device failed!\n");
   return result;
  //Caller should also setup pull method and setup capabilities(id,name,phys,bits) of the
  //corresponing  input_dev structure
  return result;
static int __devexit mma7660_remove(struct i2c_client *client)
  int result;
  result = i2c_smbus_write_byte_data(client,MMA7660_MODE, MK_MMA7660_MODE(0, 0, 0, 0, 0, 0, 0));
  assert(result==0);
  free_irq(mma7660_i2c_client->irq, NULL);
  sysfs_remove_group(&client->dev.kobj, &mma7660_group);
  hwmon_device_unregister(hwmon_dev);
  return result;
#ifdef CONFIG_PM
static int mma7660_suspend(struct i2c_client *client, pm_message_t mesg)
  int result;
  assert(result==0);
  return result;
static int mma7660_resume(struct i2c_client *client)
  int result;
  assert(result==0);
  return result;
#else
#define mma7660_suspend  NULL
#define mma7660_resume  NULL
#endif /* CONFIG_PM */
static const struct i2c_device_id mma7660_id[] = {
{ MMA7660_DRV_NAME, 0 },
MODULE_DEVICE_TABLE(i2c, mma7660_id);
static struct i2c_driver mma7660_driver = {
  .driver = {
   .name = MMA7660_DRV_NAME,
   .owner = THIS_MODULE,
  .suspend = mma7660_suspend,
  .resume = mma7660_resume,
  .probe = mma7660_probe,
  .remove = __devexit_p(mma7660_remove),
  .id_table = mma7660_id,
static int __init mma7660_init(void)
  return i2c_add_driver(&mma7660_driver);
static void __exit mma7660_exit(void)
  i2c_del_driver(&mma7660_driver);
MODULE_DESCRIPTION("MMA7660 3-Axis Orientation/Motion Detection Sensor driver");
MODULE_LICENSE("GPL");
MODULE_VERSION("1.1");
module_init(mma7660_init);
module_exit(mma7660_exit);
