I want to make a QT1 work with an external crystal, but it doesn´t work.
Here is my Init code:
// Función: InitHard()
// Descripción: inicializa los ports y registros CONFIG
void InitHard(void){
unsigned int i;
CONFIG1=0b00111001;
DDRA=0b00000011;
CONFIG2=0b00011000;
i=0xffff;
while(i!=0) {i--;} //delay
asm bset 1,OSCSTAT
i=0xff;
asm{
XXX: brclr 0,OSCSTAT,XXX
INTSCR=0b00000010; //falling /des habilitada
return;
It stops on XXX: brclr 0,OSCSTAT,XXX.
The oscillator it´s not working, I cheked that with an oscilloscope.
What could be the problem?
Does anyone have a code example?
Thank you,
gustavo.
