use of 50Mhz external reference clock in k60
Question asked by Arun Kumar on Mar 3, 2015
Latest reply on Mar 13, 2015 by Arun Kumar
We plan to remove the 50Mhz crystal from our design,will it cause any problems with our core MCU(MK60FN1MOVLQ15)
There is a 12Mhz crystal present already and we plan to run the controller with the following modules enabled.
There will be two PLLs used,96Mhz for USB and 150Mhz for normal operations
We plan to use :
Ethernet
USB (with 96Mhz PLL)
SD card
Two UART modules
PWM modules
DMA modules
Thanks in advance,
Arun
