RIoTboard : "sm_test" & "tcrypt" in order to use the CAAM encryption
Question asked by fmajeric on Mar 2, 2015
Dear All,
I bought an RIoTboard with an iMX6solo embedded processor.
I download on the element14 web site the source code, and compiler on git page:
The source code are from here : http://www.element14.com/community/docs/DOC-68442/l/riotboard-bsp-images-and-tools-download--android-and-linux?ICID=sbc-riotboard-topban
i.e. :
- BSP Linux ubuntu v3.0.35 : http://downloads.element14.com/downloads/riotboard/Linux/image_SVN2487.zip?COM=RIoTboard
- Mfg Tool : http://downloads.element14.com/downloads/riotboard/Linux/tools_SVN2652.zip?COM=RIoTboard
- Compiler tools from : $git clone git://github.com/embest-tech/fsl-linaro-toolchain.git
I want to use "sm_test.c" and "tcrypt.c" which seem to be kernel modules.
I tried to compile “sm_test.c” with this Makefile :
# Makefile for Freescale iMX6solo modules
export ARCH=arm
export CROSS_COMPILE=/home/fmajeric/Bureau/Board/Riotboard/Sources/fsl-linaro-toolchain-master/bin/arm-fsl-linux-gnueabi-
obj-m := sm_test.o
KDIR := /home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0
PWD := $(shell pwd)
all:
$(MAKE) -C $(KDIR) M=$(PWD) modules
clean:
$(MAKE) -C $(KDIR) M=$(PWD) clean
But the compiler return me this error :
fmajeric@fmajeric-VirtualBox:~/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam$ make
make -C /home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0 M=/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam modules
make[1]: Entering directory '/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0'
CC [M] /home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam/sm_test.o
/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam/sm_test.c: In function 'caam_sm_example_init':
/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam/sm_test.c:174:17: error: dereferencing pointer to incomplete type
/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam/sm_test.c: In function '__inittest':
/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam/sm_test.c:800:1: warning: return from incompatible pointer type [enabled by default]
/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam/sm_test.c: In function '__exittest':
/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam/sm_test.c:801:1: error: 'caam_sm_example_shutdow' undeclared (first use in this function)
/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam/sm_test.c:801:1: note: each undeclared identifier is reported only once for each function it appears in
/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam/sm_test.c: At top level:
/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam/sm_test.c:801:1: error: 'cleanup_module' aliased to undefined symbol 'caam_sm_example_shutdow'
scripts/Makefile.build:311: recipe for target '/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam/sm_test.o' failed
make[2]: *** [/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam/sm_test.o] Error 1
Makefile:1360: recipe for target '_module_/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam' failed
make[1]: *** [_module_/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0/drivers/crypto/caam] Error 2
make[1]: Leaving directory '/home/fmajeric/Bureau/Board/Riotboard/Sources/linux-imx/linux-imx-embest_imx_3.0.35_4.0.0'
Makefile:13: recipe for target 'all' failed
make: *** [all] Error 2
Also I tried to compile “tcrypt.c” with this Makefile:
export ARCH=arm
obj-m := tcrypt.o
PWD := $(shell pwd)
all:
clean:
And it succeed.
I copy the file “tcrypt.ko” on my board.
Try a insmod and I have this error :
root@linaro-ubuntu-desktop:/home/linaro/Dev# ls
tcrypt.ko
root@linaro-ubuntu-desktop:/home/linaro/Dev# lsmod
Module Size  Used by
vivante 943  1
drm 137754  2 vivante
root@linaro-ubuntu-desktop:/home/linaro/Dev# insmod tcrypt.ko
alg: hash: Failed to load transform for md4: -2
alg: skcipher: Failed to load transform for ecb(blowfish): -2
alg: skcipher: Failed to load transform for cbc(blowfish): -2
alg: skcipher: Failed to load transform for ecb(twofish): -2
alg: skcipher: Failed to load transform for cbc(twofish): -2
alg: skcipher: Failed to load transform for ecb(serpent): -2
alg: hash: Failed to load transform for sha384: -2
alg: hash: Failed to load transform for sha512: -2
alg: skcipher: Failed to load transform for ecb(cast5): -2
alg: skcipher: Failed to load transform for ecb(cast6): -2
alg: hash: Failed to load transform for crc32c: -2
alg: skcipher: Failed to load transform for ecb(tea): -2
alg: skcipher: Failed to load transform for ecb(xtea): -2
alg: skcipher: Failed to load transform for ecb(khazad): -2
alg: hash: Failed to load transform for wp512: -2
alg: hash: Failed to load transform for wp384: -2
alg: hash: Failed to load transform for wp256: -2
alg: skcipher: Failed to load transform for ecb(tnepres): -2
alg: skcipher: Failed to load transform for ecb(anubis): -2
alg: skcipher: Failed to load transform for cbc(anubis): -2
alg: hash: Failed to load transform for tgr192: -2
alg: hash: Failed to load transform for tgr160: -2
alg: hash: Failed to load transform for tgr128: -2
alg: skcipher: Failed to load transform for ecb(xeta): -2
alg: skcipher: Failed to load transform for pcbc(fcrypt): -2
alg: skcipher: Failed to load transform for ecb(camellia): -2
alg: skcipher: Failed to load transform for cbc(camellia): -2
alg: skcipher: Failed to load transform for salsa20: -2
alg: hash: Failed to load transform for rmd128: -2
alg: hash: Failed to load transform for rmd160: -2
alg: hash: Failed to load transform for rmd256: -2
alg: hash: Failed to load transform for rmd320: -2
alg: skcipher: Failed to load transform for ecb(seed): -2
alg: pcomp: Failed to load transform for zlib: -2
alg: hash: Failed to load transform for hmac(sha384): -2
alg: hash: Failed to load transform for hmac(sha512): -2
alg: hash: Failed to load transform for xcbc(aes): -2
alg: hash: Failed to load transform for hmac(rmd128): -2
alg: hash: Failed to load transform for hmac(rmd160): -2
alg: hash: Failed to load transform for vmac(aes): -2
alg: cprng: Failed to load transform for ansi_cprng: -2
tcrypt: one or more tests failed!
insmod: error inserting 'tcrypt.ko': -1 Attempting to link in too many shared libraries
Moreover during the u-boot session I’ve set “caam” in bootargs.
So I don’t understand what is wrong.
I think the problem is my kernel version... (3.0.35_4.0.0)
Anybody have a suggestion ?
Cheers,
Fabien.
