Unable to see the terminal from Minicom
peterzheng
Yesterday, my board was unable to boot up. Showing some error message like:
[0] panic: fdt too large: 4294967294 bytes
In order to resolve this isse, I google it, and I saw this post.
Kernel panic boot fsl-image-full on p1020rdb boards
So I just followed the answer inside. However, after I follow the command, it seems I am unable to see the system from my minicom. I tried to restart both host and board. But still, cannot see anything from minicom which is working properly before.
Did I accidentally brick my machine?
Can anyone help with this?
Thanks & Regards,
Peter
peterzheng
Problem solved by restoring the system using CodeWarrior
