About mkv playback in jb4.2.2_1.1.0 (i.MX6DL)
keitanagashima
Senior Contributor I
Dear Sir or Madam,
Hello.
I'd like to know the support for video decoder of mkv.
OS: jb4.2.2_1.1.0 (L3.0.35)
One mkv file not played.
Refer to below log.
I/OMXPlayer( 3801): LEVEL: 1 FUNCTION: InitCoreParser LINE: 1019
I/OMXPlayer( 3801): fail to create the parser: -120
I/OMXPlayer( 3801): LEVEL: 1 FUNCTION: SysEventHandler LINE: 1581
I/OMXPlayer( 3801): OMX.Freescale.std.parser.fsl.sw-based rreport Error 8000100b.
But, another mkv file played successfully.
I analysed two mkv file by MediaInfo.
- Failed mkv file : Format version  : Version 4 / Version 2
- Success mkv file : Format version  : Version 2
[Question]
Is it support the mkv (Version 4 / Version 2) in jb4.2.2_1.1.0?
Keita
Labels (6)
saurabh206
Senior Contributor III
Keita
What is audio codec with not playing mkv file?
It may possible Audio codec is not supported.
Saurabh
keitanagashima
Hi Saurabh,
I attached the codec details.
Please check the attached file.
Keita
saurabh206
Keita
Audio file is AC3 ,DTS.
You have special library for these codec and integration patches.
If yes than it should work.
Saurabh
keitanagashima
Hi Saurabh,
Thank you for your reply.
My customer had already patched these special library.
But, the software (android jb4.2.2_1.1.0) can only playback "Noah.2014.mkv".
(Other contents couldn't playback.)
The finite difference of the content which can be play or not.
Keita
SergioSolis
Hello Keita,
So of the list you show in the excel sheet, only the Noah file can play?
keitanagashima
Hi Sergio,
Yes.
Other .mkv files can't play.
Keita
SergioSolis
Would you test with our latest parser library in recently android release?
I think the issue has been resolved before.
The file - fsl_parser.h was need to replace in android/device/fsl-codec/ghdr/common
and the patch need to reply in android/external/fsl_imx_omx.
keitanagashima
Hi Sergio,
My customer tested with attached library (+ header and patch).
All MKV files could be playback.
But,  Memory leak was happened.
When the media scan runs with many numbers of the content media, OS (android) is made to restart by Memory leak.
We'd like to apply this logic to provided library for jb4.2.2.
Keita
SergioSolis
Would you please test with the video clips about memory leak?
What kind of file cause that,mkv, mp4 or other type of file?
Please help to reduce the range or can you shrare the clip which has the issue.
Does the momery leak happen only after mkv parser updated?
keitanagashima
Dear Sergio,
Hello.
.mkv files.
>Please help to reduce the range or can you share the clip which has the issue.
The clip is too big size about 2GB...
I'll talk my customer about way of detail reproduction.
>Does the memory leak happen only after mkv parser updated?
Yes. it happened after mkv parser updated.
Keita
SergioSolis
Hello Keita,
if its possible to share the video it would help.
keitanagashima
Hi Sergio,
OK. Now, my customer is trying to reproduce the issue with another video clip of small size.
Please wait a few days.
Keita
SergioSolis
Ok then, we really need to have the video file. You can use transweb to send large files if you need. We are waiting for it to continue with support.
keitanagashima
Hi Sergio,
And, I apologies for the delay in replying to you.
Now my customer is trying to reproduce this issue by small size clips.
But, it wasn't reproduce.
So, we consider how to send the big size clips in local side.
If I get the contents, I'll send you the clips by transweb.
(Please send me your e-mail address by message.)
Keita
SergioSolis
Hello Keita,
Please see our apps engineer response:
mkv parser with previous version can not recognize the file, so media scanner will not work for these files and no memory cost when scanning the file.
new parser can recognize them and it will report metadata for these files, media scanner need to send the value to java layer then store them in database, that's why free memory is reducing.
I have tested the file you sent to me with mkv parser's unit test.
No memory leak was found between parser delete and parser create.
keitanagashima
Hi Sergio,
Now, we are confirming again and this may take a while to research detail steps this problem.
Please wait for a few weeks.
Keita
