K60-100MHz UART Receive and Transmit with Interrupt
Question asked by pallenna PRSR on Feb 26, 2015
Latest reply on Mar 2, 2015 by jeremyzhou
Hi Adrian Sanchez Cano,
I have tried to receive the data from serial port in polling method and ISR it is working fine,but when i am trying to  transmit the data to serial port using polling is working but with ISR it is not working.and i have one more doubt about UART ISR i.e UART RX,TX have same ISR or not and how to enable the ISR for TX and RX at the same time. i am already tried this but i cant get both the data i.e serial port to UART and UART to serial port,and i followed your reference code UART driver with ISR.zip but i can not get the output for TX,RX at same time and how to get both the TX,RX ISR at a time please send if have any example code with main function and already i have your UART driver code now i want main function using ISR please be provide for reference.
Thanks and Regards,
padmaja
