The MPC5200B datasheet specifies the DDR SDRAM read timing parameters for data setup and hold relative to MDQS but shows data setup as a max parameter? The SpecID is A5.18. Can someone explain what is meant by maximum setup time allowed? Also the data hold time is listed as a minimum number (2.6ns), my question here is if this relative to MDQS before it is shifted by a 1/4 clock?
