IMX287: supported linux versions
Question asked by Kirill Brilliantov on Feb 25, 2015
Latest reply on Feb 25, 2015 by Kirill Brilliantov
Hello!
Now I use linux-2.6.35 and gcc-4.4.4 from LTIB (L2.6.35_1.1.0_130130_source.tar.gz), unfortunately current linux not supported some devices and I think use another version.
I clone linux-3.10.53 from /git.freescale.com/git/cgit.cgi/imx:
$ git clone -b imx_3.10.53_1.1.0_ga http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git linux-3.10.53
Unfortunately git protocol not work:
$ git clone --depth=1 -b imx_3.10.53_1.1.0_ga git://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git linux-3.10.53_2
Cloning into 'linux-3.10.53_2'...
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
For test I use default configuration:
$ cd linux-3.10.53/
$ make ARCH=arm mxs_defconfig
$ make -j5 ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.4.4-glibc-2.11.1-multilib-1.0/arm-fsl-linux-gnueabi/bin/arm-fsl-linux-gnueabi-
I patch net/core/tso.c for fix build error, please see attache:
net/core/tso.c:16: error: implicit declaration of function 'tcp_hdrlen'
net/core/tso.c:24: error: dereferencing pointer to incomplete type
net/core/tso.c:29: error: dereferencing pointer to incomplete type
net/core/tso.c:30: error: dereferencing pointer to incomplete type
net/core/tso.c:31: error: dereferencing pointer to incomplete type
net/core/tso.c: In function 'tso_start':
net/core/tso.c:57: error: implicit declaration of function 'tcp_hdr'
net/core/tso.c:57: error: invalid type argument of '->' (have 'int')
make[2]: *** [net/core/tso.o] Error 1
Unfortunately I can't buil linux:
drivers/built-in.o: In function `mxsfb_dispdrv_init':
/home/kirill/Projects/IMX287/linux-3.10.53/drivers/video/mxsfb.c:1202: undefined reference to `mxc_dispdrv_gethandle'
drivers/built-in.o: In function `regulator_disable':
/home/kirill/Projects/IMX287/linux-3.10.53/drivers/regulator/core.c:1787: undefined reference to `set_cpufreq_lock'
drivers/built-in.o: In function `rdev_get_name':
/home/kirill/Projects/IMX287/linux-3.10.53/drivers/regulator/core.c:122: undefined reference to `set_cpufreq_lock'
drivers/built-in.o: In function `mxs_phy_probe':
/home/kirill/Projects/IMX287/linux-3.10.53/drivers/usb/phy/phy-mxs-usb.c:600: undefined reference to `syscon_regmap_lookup_by_phandle'
drivers/built-in.o: In function `imx_controller_resume':
/home/kirill/Projects/IMX287/linux-3.10.53/drivers/usb/chipidea/ci_hdrc_imx.c:526: undefined reference to `request_bus_freq'
/home/kirill/Projects/IMX287/linux-3.10.53/drivers/usb/chipidea/ci_hdrc_imx.c:568: undefined reference to `release_bus_freq'
drivers/built-in.o: In function `imx_controller_suspend':
/home/kirill/Projects/IMX287/linux-3.10.53/drivers/usb/chipidea/ci_hdrc_imx.c:508: undefined reference to `release_bus_freq'
drivers/built-in.o: In function `ci_hdrc_imx_remove':
/home/kirill/Projects/IMX287/linux-3.10.53/drivers/usb/chipidea/ci_hdrc_imx.c:480: undefined reference to `release_bus_freq'
drivers/built-in.o: In function `ci_hdrc_imx_probe':
/home/kirill/Projects/IMX287/linux-3.10.53/drivers/usb/chipidea/ci_hdrc_imx.c:314: undefined reference to `request_bus_freq'
/home/kirill/Projects/IMX287/linux-3.10.53/drivers/usb/chipidea/ci_hdrc_imx.c:317: undefined reference to `release_bus_freq'
/home/kirill/Projects/IMX287/linux-3.10.53/drivers/usb/chipidea/ci_hdrc_imx.c:374: undefined reference to `syscon_regmap_lookup_by_phandle'
/home/kirill/Projects/IMX287/linux-3.10.53/drivers/usb/chipidea/ci_hdrc_imx.c:465: undefined reference to `release_bus_freq'
make: *** [vmlinux] Error 1
Questions:
- how can I solve errors?
- what linux versions FreeScale support for iMX287?
Thank you and excuse my bad english.
Original Attachment has been moved to: 0001-net-core-tso.c-implicit-declaration-of-function-tcp_.patch.zip
