About a Audio error and application abnormal termination for AndroidKK4.4.2 on i.MX6-SABRE-SDB.
Question asked by yuuki on Feb 23, 2015
Latest reply on Apr 29, 2015 by SergioSolis
Branched to a new discussion
Our customer is using the following development environment.
<Environment>
Baord: MX6Q-SABRE-SDB
Display: HDMI output
OS: AndroidKK4.4.2 FSL BSP
Package: AndroidKK4.4.2_Extended Feature Packages(android_kk4.4.2_1.0.0-ga_omxplayer_source)
Patchs: 0001-Fix-the-video-only-stream-can-t-play-issue.patch
             html5_video_issue.patch
When a Video playback is repeated, the following error occurs.
And It seems that a Video application is finished forcibly(abnormal termination).
=====Error log=====
I/OMXPlayer( 2291): failed to open file: /data/system/audio_pass_through_pref.
W/linker  ( 2291): lib_aac_dec_v2_arm12_elinux.so has text relocations. This is wasting memory and is a security risk. Please fix.
W/linker  ( 2291): lib_aacplus_dec_v2_arm11_elinux.so has text relocations. This is wasting memory and is a security risk. Please fix.
Are these errors related to abnormal termination?
May I have advice?
Yuuki
