K60-100MHz UART Receive with Interrupt
pallenna
Dear Friends,
I have tried the data receive from Serial port with UART  in polling mode it is working fine but when i am trying with Interrupt it is going to default ISR please suggest me and if any body have example code please post here. And i am posting the code what am using please correct me any mistakes are there.I am asking this for K60 with 100MHz Tower. I have already tried this with K60-120 there it is working fine and am facing problem with K60-100 Board. Please suggest me.
Thanks & Regards,
Padmaja.P
Original Attachment has been moved to: uart.c.txt.zip
Original Attachment has been moved to: isr.h.txt.zip
Tags (2)
adriancano
I already answered to you in the thread:
UART transmition in isr for k60
it is a similar question.
Hope this information can help you
Adrian Sanchez Cano
Technical Support Engineer
