Hi all.
I'm the user of MK10 series. Nowadays i'm trying for coding the boot-load code by using P-flash region.
I already read the AN2295 and that S/W. But i couldn't understand bootloader exactly.
Could you give me some application note or example code?
Thank you!
Hi Eunseok Jung,
Maybe you find useful these Application Notes. There are about Bootloader and Flash memory.
AN4370 USB DFU Bootloader for MCUs https://www.freescale.com/files/microcontrollers/doc/app_note/AN4370.pdf
AN4367 Ethernet Bootloader for MCU https://www.freescale.com/files/microcontrollers/doc/app_note/AN4367.pdf
But I will check the information with P-Flash AN with product manager and tell you.
Iva
Thanks Iva.
If you find something, plz reply in here.
Best,
Eunseok
Hi Eunseok Jung,
I got the information that any other AN with this topic does not exist.
Iva
Hi Eunseok,
everything what we can offer to you regarding application note AN2295 isthe following revision of the appnote with the sw pack:
document: http://cache.freescale.com/files/microcontrollers/doc/app_note/AN2295.pdf
sw: http://cache.freescale.com/files/microcontrollers/doc/app_note/AN2295SW.zip
What would you like to know ?
Pavel
Thanks pavel.
I already read the AN2295 and its software.
Do you know another reference or application note?
All about this bootloader is written in the AN2295, another application note does not exist in the meantime. But many interesting information you can find on the Freescale community. If you have more deeper questions, we can open the discussion.
Regargs,
Pavel
Hi Eunseok,
you mentioned the AN2295, I thought that you are only interest for this implementation of the bootloader. :smileyhappy: Freescale offers to the customers other bootloaders implementation based on different communication interfaces (UART, SPI, I2C, USB HID).
FYI: The latest information about the Kinetis ROM bootloader you can find here: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=KBOOT
(may be helpful for the developing of your own bootloader)
Pavel
