I'm moving computers and setting up on a new laptop. Installed CodeWarrier, but I can't get a "Connection Type/Target Type". On my old computer, a list of targets in the "Target Type" drop box, such as "hcs08.HCS08JM" drops down automatically. In my new setup, the list is bare, not populated.
How can I get the list populated?
Cheers
Thanks for your help. I have uninstalled and re-installed in the c:\Freescale folder. Seems to be working well now. Thanks again.
Hello Dom Frencken,
Maybe your problem is related to this thread:
Re: KL05Z Example LED_Blink debug not possible
Confirm that you installed CodeWarrior in C:\Freescale path.
Regards!
Jorge Gonzalez
Hi Don,
I've checked on my side with MCU v10.6 + all patches and updates.
PC config: Win 7 64 bit.
I've tried to create a new configuration for a demo project example for JM68.
As you can see below it's working:
Can I recommend you to try with a new project ?
May be your project is corrupted.
Else you can re-install the tool.
Pascal
Freescale Technical Support
