Permanent settings in KDS
jiripospisil
Hi friends,
Today I learned to work with the pod "FRDM-K20D50M". And I have a problem with the program KDS.
Whenever I create a new project, I have set (see. Figure):
select -> Build configuration -> Debug
Mark -> Select configuration using C / C ++ application
Is there a way to make this setting permanent?
thank you
Tags (2)
ivadorazinova
Hi Jiri Pospisil,
ïf you build your project, go to the Debug Configuration and if you have no mark the option, mark it, it should be permanent set after "Apply" and "Debug".
You should have correct settings in Debugger tab.
Do you debug successfully?
Iva
