Error while building x264
abhinavbipnesh
I was trying to build x264 for t1040rdb  and it get failed with below error log
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function do_configure
| No working C compiler found.
When I check the config.log file it reports below error
Failed commandline was:
powerpc-fsl-linux-gcc  -m32 -mhard-float -mcpu=e5500 --sysroot=<sysroot dir> conftest.c  -  O2 -pipe -g -feliminate-unused-debug-types -Wall -I. -I$(SRCPATH) –sysroot=<sysroot dir>  - maltivec -mabi=altivec   -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed --sysroot=<sysroot dir> -lm -o conftest
conftest.c:1:0: error: AltiVec not supported in this target
  int main () {  return 0; }
Failed program was:
DIED: No working C compiler found.
So any thoughts how to fix this issue.
Abhinav
Tags (3)
