Hi Vadim
I believe this is possible, in particular this option is mentioned in
MMPF0200 Table 70. SW3A/B External Component Requirements
Hi Igor,
Thank you. Unfortunately your reference to Table 70 is applicable to SW3A/B only and I'm not sure if the SW1A/B feedback loop is stable with 2x22uF output capacitors.
Vadim
