make linux-menuconfig和make menuconfig的区别
mingmingyuan
mingmingyuan
USB to Ethernet adapter - ArmadeusWiki
这个链接是飞思卡尔工程师给我的,让我按照这里面的步骤走,这里提到到make linux-menuconfig,我也没见过make linux-menuconfig,所以才提出来与飞思卡尔工程师确认下,结果倒好,您说是浪费时间,要是浪费也是飞思卡尔浪费我的时间,明天就是新年了,不想说难听的,但是您说话太过分了,就您和您同事这组合,一个工程师给客户错误信息,我在确认过程中被另一个工程师说是浪费时间,就你们这态度,这行为,早晚把客户都弄丢了,公司倒闭加失业!
SergioSolis
Hello Mingming,
I did a quick search on google and found the following link:
Chapter 4. Customization
The Linux kernel configuration can be customized just like BusyBox Section 4.2, “Customizing the Busybox configuration” and uClibc Section 4.3, “Customizing the uClibc configuration” using make linux-menuconfig. Make sure you have enabled the kernel build in make menuconfig first.
As I understood, you use linux-menuconfig to modify the linux kernel, but in order to do that you need to enable it in make menuconfig.
