Hi JackD
My reply (very late from your post...) just to know if you have solved this problem......
I have the same problem: keep active the external bus for a big SDRAM banks but with internal flash secured from undesiderable BDM access!!
Have you solved?
Have you received a valid hints from Freescale people or from this forums?
Thanks in advance for the reply
