Hello IAR EWARM experts,
I posted this issue to the ARM Connected Community but have not been received any responses.
Therefore I would like to post to this site.
I would like to know how to describe a naked attribute function.
The code was compiled successfully with a standalone GCC but IAR GCC could not and display the following error messages.
エラー[Pe079]: expected a type specifier D:\KL25 Sample Code\kl25_sc_rev10\klxx-sc-baremetal\src\projects\svc_demo\svc_demo.c 238
エラー[Pe141]: unnamed prototyped parameters not allowed when body is present D:\KL25 Sample Code\kl25_sc_rev10\klxx-sc-baremetal\src\projects\svc_demo\svc_demo.c 238
エラー[Pe130]: expected a "{" D:\KL25 Sample Code\kl25_sc_rev10\klxx-sc-baremetal\src\projects\svc_demo\svc_demo.c 238
C/C++コンパイラ 実行中のエラー
Can anyone help me?
Thank you and best regards,
Yasuhiko Koumoto.
Solved! Go to Solution.
Yasuhiko
These type of things are not standard and so are compiler specific.
You can use a define instead and declare the define according to the compiler used and then it is automated.
Mark
Kinetis: http://www.utasker.com/kinetis.html
For the complete "out-of-the-box" Kinetis experience and faster time to market
Hi Yasuhiko
Try the non-standard extended keyword __stackless
Mark
Hi Mark,
thank you, the compilation was done successfully with __stackless.
However, the __stackless keyword was not accepted by the standalone GCC.
Is it IAR specific keyword?
Yasuhiko Koumoto.
Yasuhiko
Mark
Hi Mark,
thank you for good advice. I agree with you.
Yasuhiko Koumoto.
