May I not populate PF0100 F0 SWBST components?
MehmetAliIpin
Contributor V
Dear Sir/Madam,
We have a project with I.MX6 dual/quad core processor which we use PF0100 F0 as PMIC. For USB I have another 5 volts supply already and therefore I don't want to populate SWBST components in PCB. Does it cause stability problems to PF0100 F0?
Thanks and best regards.
Mehmet Ali
Tags (2)
durmus
Hi Mehmet Ali,
You should check out the following document:
http://cache.freescale.com/files/analog/doc/app_note/AN4717.pdf
For every pin, there is a column for "Recommended connection when not used".
For your specific question, it says in the document:
44 - SWBSTFB --> Leave floating
45 - SWBSTIN --> Connect to VIN
46 - SWBSTLX --> Leave floating
Durmuş
durmus
Hi Mehmet Ali,
Durmuş
MehmetAliIpin
Contributor V
Thank you,
I found and read AN4717 after I asked the question.
Best regards.
Mehmet Ali
